89 Users Online (87 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Beams with non-orthogonal end
Mon, Jan 11, 2010 at 9:16:59 AM | Beams with non-orthogonal end
lewis001
I've got a beam that spans from a wall and goes out to the face of a slab. the beam is square to the wall but the slab is curved. is it possible to make the end of the beam curve the same as the slab? if yes, any help on how to do this would be greatly appreciated.
Mon, Jan 11, 2010 at 12:22:29 PM | Beams with non-orthogonal end
emgeeo
3.5 Stars: 7 Votes
Opening by face in the 'Modelling' tab.  You may even be able to lock the sketch to the slab...making it semi-parametric.
Mon, Jan 11, 2010 at 12:25:39 PM | Beams with non-orthogonal end
pdoug
3 Stars: 2 Votes
You can modify the ends of the beam by editing the beam family.  Select the beam, right click, select edit family.  Do a save as so you do not override the original family.  Create a void extrusion at the end of the beam desired.  If you have many beams to do this to - this could take awhile as you would have a different family for each end condition.
This is just one way I am sure.  It sounds like you're trying to accomplish this to provide renderings perhaps?  Otherwise I wouldn't even bother trying to model the end condition, instead modify the end in your detail view with a masking region and detail lines to get what you want...
Battered ends of L-Beams
Thu, May 9, 2013 at 12:32:50 PM
Beam start/end extension
Fri, Feb 12, 2010 at 10:59:48 AM
Offset Level of Steel Beams - Start/End or Z
Tue, Dec 2, 2014 at 10:24:31 AM
Arcs and non-orthogonal geometry
Wed, Dec 28, 2005 at 9:49:46 PM
Structural Member End
Tue, Jul 5, 2005 at 5:38:43 AM
Page generation time: 0.5363
