86 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Shear studs on Steel Beam Family
Fri, Jan 8, 2010 at 8:19:19 PM | Shear studs on Steel Beam Family
rex916
Hi Everyone,
I am trying to create a family that shows a shear stud on top of a beam when cut in section. I created a family using the out of the box beam family and modifying it to show the shear stud.
Next, I added some parameters to tie in my shear stud. I am using a detail component and symbolic lines for the shear stud.
Following, I loaded the family into a project. At the second floor it drops my beam according to the shear stud parameter that I added to tie in my stud. Not sure why revit keeps thinking that my shear stud is a model object.
I also made the shear stud as a graphic, but it still keeps droping my beam as indicated above.
I am trying to accomplish having all my section draw the shear stud instead of manually placing shear studs in all section views. I attached some screen shots (pdfs) so you guys can see what is going on.
Edited on: Fri, Jan 8, 2010 at 8:21:38 PM
Wed, Feb 3, 2010 at 6:04:56 PM | Shear studs on Steel Beam Family
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
In your modified beam family, make sure that you have the top of beam work plane saved as origin with strong reference.
Wed, Jul 25, 2012 at 5:48:17 PM | Shear studs on Steel Beam Family
joshr
I'm having the same issue, only with a 3D stud on the beam instead of 2D. The solution in the second post does not work. I've tried messing with different reference plane types and properties to no avail. If there are lines or geometry above the top of the beam in the family, it affects the beam's top elevation in the project.
Anyone know how to fix this?
Wed, Feb 26, 2025 at 5:57:33 AM | Shear studs on Steel Beam Family
chauhuh
As far as I know this isn't possible. You can adjust the z-offset though to get the desired top of beam height.
-Chau
2D detail item nested to Steel Beam family - Placing level problem
Fri, Jan 13, 2012 at 12:00:35 AM
Steel Beam to Beam Connection
Fri, Jun 18, 2010 at 1:54:36 PM
Strange behavior: family automatically snapping to other family....?
Fri, Nov 27, 2015 at 4:24:06 AM
Mitered beams at will not stay mitered when I connect a end shear plate
Fri, Sep 9, 2016 at 10:34:18 AM
Fabsec Steel Beam Families
Wed, Nov 8, 2006 at 1:43:28 PM
Page generation time: 7.5280
