Forums >> Revit Building >> Technical Support >> fonts
16 Posts No Rating |
Does any one have true type fonts with compressed fractions in diagonal or horizontal format.
3 Posts No Rating |
The Architxt True Type has the 1/2, 1/4, and 3/4 diagonally stacked fractions. I am not sure the key strokes, but I usually just pull up the character map and insert them. See Attached)
I know the keystrokes to those fractions using that font but how do you add more fractions.
You can't add fractions to fonts unless you have the tools and knowledge to create fonts. The charmap tells you what is available.
DOES ANY ONE KNOW A FONT THAT HAS ALL THE FRACTIONS IN IT AND IS SIMILAR TO ARCHITXT
Check out this thread: http://www.revitcity.com/forums.php?action=viewthread&thread_id=4070
1 Posts No Rating |
I used to use the old Archtxt TTF but did have problems with it actually flipping over on itself in pdf files at times. I bought Mr. Hand and Heavy Hand a few years back and never had a problem with them. Set the font width to .8, as 3/32" text notes and dimensions tend to be a little too wide without that. They also come with 4 other hand fonts, for $45. They include the major fractions, too. Here's the link I found on line : http://www.will-harris.com/store-h/architect_fonts.htm
Arnie Bunkley, AIA · AB2 Architecture · Portage, MI |
Fonts For Revit |
Mon, Oct 8, 2007 at 8:19:04 AM
FONTS! |
Thu, May 4, 2006 at 2:47:00 PM
Archival Fonts? |
Thu, May 19, 2016 at 6:32:25 AM
Revit fonts that match AutoCad .shx fonts |
Thu, Jun 14, 2007 at 3:52:15 PM
What Do All The Fonts Look Like |
Wed, May 6, 2015 at 7:23:40 AM
Members: | 2097865 | Objects: | 23164 | Forum Posts: | 152288 | Job Listings: | 3 |
