91 Users Online (87 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Tips & Tricks >> Beam to beam connections
Fri, Jan 8, 2010 at 5:00:56 AM | Beam to beam connections
jeanke
I have a question , i'm new at revit ( i'm using revit structure) . I need to make structures for industrial use ( level constrution for putting machines on) . But to do that i need make bolded connections with beam to colums and to griders . I can't find any top - or end plates in revit :-(
Can anybody tell me how i can do that so that the manufacture for the construction can start to make my platforms!Or is revit structure just made for designing analytic models and no detailted designs?
WKR
jeanke
Fri, Jan 8, 2010 at 10:49:03 AM | Beam to beam connections
pdoug
3 Stars: 2 Votes
jeanke,
When I saw your post in the Tips and Tricks section of the forum I thought "Nice, someone has a tip for beam-2-beam connections!" But when I opened your post it was a question...Please try next time to post in the REVIT STRUCTURE - Technical Support - your post might not get missed!  There's also a newbie section too.
To answer your question...I haven't seen much in the way for model entities for bolts or connection plates.  There is an extension which creates beam to column connections, but it is limited.  You can search autodesk's website for the latest extensions to try it out for yourself and it may have come with your version of the software - (I can't remember exactly how I got them - brain cramp) But if you have already installed them they would be located under the add-ins tab on the ribbon.
Other than that, you could try creating mass elements.  What is the purpose for showing modeled connection material versus drawing 2D details of the different connection types?
Wed, Nov 14, 2012 at 1:24:03 PM | Beam to beam connections
MichLMcCarthy
I know this is a bit of an old post, but if you want to try getting beam to beam structural connections, they are supported by the SDS/2 Connect add-in for Revit Structure. They are complete with design calculations as well.
These videos on our YouTube channel can show you how it works: http://www.youtube.com/playlist?list=PLCBB2A3F56AECECEB&feature=plcp
OR see for yourself by getting a free trial: http://sds2connect.com/trial
My beam i designed is wider than my column
Tue, Apr 2, 2013 at 8:16:42 AM
Beam & Beam systems
Tue, Oct 21, 2008 at 4:36:55 PM
beam finishes
Wed, Sep 19, 2012 at 3:11:31 PM
Meeting Beam Systems to Glulam Beam
Wed, Jun 20, 2012 at 10:34:17 AM
Precast Beam System not sitting on beam
Thu, Jan 10, 2013 at 11:45:49 AM
Page generation time: 0.7389
