55 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> sections - level annotations
Mon, Sep 5, 2005 at 5:02:56 PM | sections - level annotations
shaun_kiwi
5 Stars: 2 Votes
Level annotations don't appear in some levels. Levels ara switched on in properties and Hide annotation in view is not toggled. I drew a new section in place of another so that I could see the levels but when I flipped the section between north and south say, the levels appeared and disappeared. Couldn't get them to appear in the direction I wanted. Any ideas????????
Mon, Sep 5, 2005 at 5:52:34 PM | RE: sections - level annotations
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Check the 3D extents of your level lines, they most likely won't be intersecting the view. Best bet to fix them is to add a scope box and apply all levels to the scope box. This will ensure the 3D extents of your levels encompass the entire model. Further reading, look up datum's in your help section.
Mon, Sep 5, 2005 at 7:33:03 PM | RE: sections - level annotations
shaun_kiwi
5 Stars: 2 Votes
Thanks chris that sorted that out.
Level Annotation Problem
Tue, Mar 13, 2007 at 1:30:54 PM
2014 Level Head Adjustment in Sections/Elevations/Etc.
Thu, Mar 13, 2014 at 1:08:44 PM
Sections, different level/views
Sat, Aug 5, 2017 at 7:34:44 AM
sections and level lines
Wed, Jul 12, 2006 at 4:39:50 PM
Text Masking in annotations
Tue, May 10, 2011 at 10:38:55 AM
Page generation time: 0.8123
