81 Users Online (80 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> TOP CHORD OFFSET DOUBLE PITCHED UNDERSLUNG LH & DLH JOIST
Wed, Jan 6, 2010 at 12:24:53 PM | TOP CHORD OFFSET DOUBLE PITCHED UNDERSLUNG LH & DLH JOIST
twade
I'm looking for a joist family that is parametrically adjustable for ridge offset, depth and length.  Does this exist somewhere or do I need to generate this myself and what would be the best way to build this family?
 Thanks..........Terry
Mon, Jan 11, 2010 at 12:36:25 PM | TOP CHORD OFFSET DOUBLE PITCHED UNDERSLUNG LH & DLH JOIST
emgeeo
3.5 Stars: 7 Votes
What do you mean by ridge offset?  What type of joist?  Wood/Steel?
Mon, Jan 11, 2010 at 3:18:53 PM | TOP CHORD OFFSET DOUBLE PITCHED UNDERSLUNG LH & DLH JOIST
twade
The top chord offset refers to the ridge point not being at the center of the joist.  We sometimes have a roof where the ridge point is not in the center of the joist and the slope will differ from one side of the ridge to the other.  I would like to have a double pitched joist family that is parametric where I could simply enter in the data needed and have the joist as required.  For the moment I have created a 3-d model of my joist and then imported into my project as a mass family.  It seems to work ok, but not really what I would like to have.  I'm pretty new to revit and I'm still learning what I can and can't do with it.
Thanks......Terry
Mon, Jan 11, 2010 at 4:39:04 PM | TOP CHORD OFFSET DOUBLE PITCHED UNDERSLUNG LH & DLH JOIST
3.5 Stars: 395 Votes
You could modify a wood truss family from this site but I would not do what you want to do.  I would look at doing a simple one slope rafter with adjustable slope.  Then just place another instance of the family with a different slope for the other half.
Edited on: Mon, Jan 11, 2010 at 4:40:10 PM
Family Needed - Top Chord Offsed Double Pitched Underslung Steel Joists
Tue, May 18, 2010 at 11:40:49 AM
double pitched top chord joist seats
Tue, Feb 15, 2011 at 3:37:51 PM
Single Pitch Top Chord Joist family?
Fri, Nov 30, 2012 at 7:49:29 AM
DLH Joist Bott. chord brg. sloped top chord
Mon, Dec 13, 2010 at 1:07:52 PM
DLH joist bottom chord bearing
Thu, Dec 9, 2010 at 8:40:09 PM
Page generation time: 0.6623
