Forums >> Revit Building >> Technical Support >> Element type Icon?
Tue, Jan 5, 2010 at 1:11:19 PM | Element type Icon?
jhendershot
Are the icons that show up when you hover over a type in the pull down menu customizable? i want to put in a section of the wall rather than the plan view. the plan view gives you pretty much zero information and would like to either have the section of the actual wall or i would even be fine with a dummy image that i would create.
see attached.
cheers.
j.
Tue, Dec 14, 2010 at 2:16:12 PM | Element type Icon?
jhendershot
anyone know where this image comes from?.. it seems odd that in the windows explorer thumbnail it looks at the front and in the component pull down menu it looks at the back? how can i switch the component pull down image to match the explorer thumbnail image?
Tue, Dec 14, 2010 at 2:37:58 PM | Element type Icon?
When you save a family, in the save GUI, you can select what view to use for the directory icon but I believe the family view is the last view the file was saved from.
Please let us know if you check this out.
Tue, Dec 14, 2010 at 2:51:06 PM | Element type Icon?
jhendershot
I looked at the file save options and have it set the way i want...3d View... save the family and load into a brand new project for the first time and it is always coming in as backwards... don't get it.
Tue, Dec 14, 2010 at 3:36:04 PM | Element type Icon?
I have always thought that Revit was a little screwey with it's Front/Back settings.  I always think that the bottom of a plan is the front and that is the way your object is modeled.  If you flip the object and put the "front" of the object up, the icon's can match because it appears that Revit creates an icon from that side no matter how it is set in the family.
Tue, Dec 14, 2010 at 3:41:20 PM | Element type Icon?
jhendershot
thanks.. that is what i kind of gathered.. i have a lot of families that are built this way and was just trying to avoid running through mirroring all of them and redoing all the dimension links..ugh.. wish i would have noticed this before creating all of these.
thanks for the info.
File Icon
Wed, Aug 29, 2012 at 10:21:14 AM
switching element type to curtain element error
Wed, Nov 16, 2011 at 1:37:03 PM
changing one element type to another type
Thu, Feb 5, 2009 at 2:11:33 PM
linking files to a model
Tue, Jun 12, 2012 at 5:22:43 PM
Element & Type Prop Windows
Wed, Sep 16, 2009 at 4:36:36 PM
Page generation time: 9.8103
