57 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Using Structural Floors instead of Architectural?? Good Idea or Bad Idea??
Tue, Jan 5, 2010 at 10:09:21 AM | Using Structural Floors instead of Architectural?? Good Idea or Bad Idea??
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
Hey Guys, I got a Question.....
      I am doing a large hospital in Revit Architecture 2010, we will be importing all consultants model into ours (Structural, MEP, etc...). We where wanting to use the clash detection part of revit on this job due to its size... My question is..
      Should we not show floors in our model and just use structurals model to show the floor slabs in section, details, etc...? or should we have a floor of our own in our model that will just overlap the structural model?? What are the advantages and disadvantages to this??
-Allen
J. Allen Ball
Revit Architecture 2010 Certified Professional
Tue, Jan 5, 2010 at 10:24:47 AM | Using Structural Floors instead of Architectural?? Good Idea or Bad Idea??
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
I would probably have floors in both models.
As I'm sure you know, if you don't have it in your model, you can't do anything to it.
So if you need to cut floor openings and things like that, you would have to wait for the RST file to get them.
You wouldn't be able to place floor hosted content...things like that.
With that said, you may want to hide your floors when it comes time for detailing as the RST package will show a filled region for structural decking, (provided they use it) and may have more accurate layering / thickness...save time on your end.
In RST, their floor have more information than what you may need in RAC. There are specific properties in there ment for an analysis package to read...aside from the analytical model.
I would probably just copy monitor them so you can track changes in shape, thickness, opening, etc.
HTH
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Tue, Jan 5, 2010 at 11:08:06 AM | Using Structural Floors instead of Architectural?? Good Idea or Bad Idea??
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
Thanks Brett, you pointed out some things that i had not thought of. I agree though. I think having a floor in my model is the way to go.
J. Allen Ball
upgrade from 2010 to 2011, good idea for tight schedule?
Mon, Jul 26, 2010 at 5:45:52 PM
Architectural Vs. Structural Linking
Tue, Feb 19, 2019 at 10:42:29 PM
2009-Topo & Pad...anyone has an idea
Tue, Jun 30, 2009 at 11:33:26 PM
Manipulate Structural Grid in Architectural model
Mon, Nov 14, 2011 at 4:11:48 PM
Monitoring Non-Copied Structural Elements
Wed, Jun 25, 2014 at 10:27:35 AM
Page generation time: 1.3136
