53 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Templates set-up
Sun, Sep 4, 2005 at 8:27:34 PM | Templates set-up
Shanzie
Hi guys/girls, How do i set-up my own template so when i start a new project all the window/doors/textsizes etc. that i use, are already load in to that project? so i don't have to keep having to load them! Shanzie
Sun, Sep 4, 2005 at 11:41:02 PM | RE: Templates set-up
eldados
eldados Avatar
4.5 Stars: 8 Votes
you will need to start a new drawings and bring all the families you want to this drawings, once you are happy with your settings, (families, line types, object style...) save as a template. just let revit know the location of this template, so when you open a new drawings it will use this template. setting up the template file the way you want it is probably the most important part of starting a project, a good template will save you alot of trouble, will take a couple or so projects to get it right... good luck
Mon, Sep 5, 2005 at 8:09:55 AM | RE: Templates set-up
latemore
latemore Avatar
3 Stars: 2 Votes
eldados is very right! i am a newbie too, and i am slowly building up a template, as we do projects. can i suggest it takes a bit more than two projects? but it is so important to keep updating it, as revit encourages constant learning which can be incorporated into the template. in my office we constantly tell each other about stuff so i can bring it into the template. but as a bit of advise to other beginners like myself - just start a project, learn as you go, and be stunned by revit's ease and power. you'll be daunted like hell, but within a few days, the project will be good enough to show your client.
Revit templates with Lineweights set
Wed, Aug 21, 2013 at 9:25:57 AM
Where have my templates gone in 2012
Sat, Apr 7, 2012 at 9:09:07 AM
Family Templates
Tue, Nov 26, 2013 at 9:56:22 AM
View Templates Not applying to view types
Mon, Nov 1, 2010 at 10:13:37 AM
Drawing templates
Thu, Jun 10, 2004 at 1:41:37 PM
Page generation time: 1.5290
