46 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> RGB Colors Don't Match
Mon, Jan 4, 2010 at 12:01:01 PM | RGB Colors Don't Match
VNessa
I have created a colored elevation where the RGB settings for my CMU and limestone are set to 215-203-168. I have created a legend with filled regions for the colors with the same RGB settings. However, they do not match each other. Any ideas on how to fix this?
 I have a file.
Mon, Jan 4, 2010 at 12:43:16 PM | RGB Colors Don't Match
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
Try using the actuall walls in your legend.
J. Allen Ball
Revit Architecture 2010 Certified Professional
Mon, Jan 4, 2010 at 1:08:55 PM | RGB Colors Don't Match
VNessa
Is it possible to create walls in a legend? If so, how?
Mon, Jan 4, 2010 at 1:17:52 PM | RGB Colors Don't Match
4 Stars: 203 Votes
Drag the walls from the project browser to that legend and in the option bar you can choose if you want that wall in plan or section view...
Mon, Jan 4, 2010 at 1:28:03 PM | RGB Colors Don't Match
VNessa
Thanks for the tip! I didn't know you could do that. I need to have an elevation though.
Also, the legend colors are correct and the elevation colors are wrong. I can't seem to adjust the elevation colors to be correct. They are always too yellow or just white.
Mon, Jan 4, 2010 at 2:47:44 PM | RGB Colors Don't Match
VNessa
I found the problem. The elevations were set with the sun from the top right at 80 and "use sun position for shaded diplay" was turned off.  When I turn on "Use sun position for shaded display" and set it to 50, the colors mathched. Thanks for the help!
Rendered Colors Don't Match
Tue, Mar 24, 2009 at 12:53:40 PM
Revit colours do not Match AutoCAD
Mon, Apr 27, 2009 at 9:05:55 AM
Room Colors don't show in R2010
Thu, Aug 13, 2009 at 11:38:19 AM
Compent colors don't show up in renderings
Tue, Apr 24, 2007 at 12:54:18 PM
Revit 2009 Rendering Accuracy
Wed, Oct 15, 2008 at 4:35:48 PM
Page generation time: 0.9227
