17 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Autocad to Revit 2010
I have a 3d autocad form that I have to convert it in to revit. Is there a easy way to do this whit out having to draw it again in Revit. Nicolai
Can import or link the CAD file into Revit. When you do just go to your Manage tab and select line styles. There is a tab in that menu that will be specifically for Imported files. You can literally change the lineweight and style of each AutoCAD layer here to best represent how you want it to look in your drawings. For the sake of creating any Elevation Views you may need, I would suggest using the imported CAD file within a Plan view as a template to at the very least draw your exterior walls, windows/doors, and roof. Hope this helps!
Exporting from Revit 2013 to Autocad MEP 2010 while retaining intelligent object |
Sat, Dec 7, 2013 at 12:08:38 AM
Having trouble import Autocad files into Revit 2010 |
Tue, Jun 9, 2009 at 8:55:02 AM
2010 classic [ 1 2 3 4 5 ] |
Thu, Apr 8, 2010 at 9:25:30 AM
70
draw order in revit 2010 |
Tue, Sep 23, 2014 at 1:24:31 PM
Import topo surface from AutoCAD to Revit?? |
Thu, Oct 17, 2013 at 12:49:05 PM
Members: | 2026013 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
