Forums >> Revit Building >> Technical Support >> Change in rafter thickness in roof
Hi, I am working on a roof that slopes up to meet a curtain wall system and creates an overhang of 4 feet. The roof is timber frame and its thickness is continously 16", except for when it meets the curtain wall it is supposed to thin out to 6". I thought I could use the Rafter Cut option, under Instance Property, but the change in rafter thickness happens to the lower side of my sloped roof! Can you please help me to get around this problem. I have attached an image I hope it helps Thank you
Have you tried selecting the roof adding a Split Line then using Modify Sub elements.
Yes, that option has just allowed for more flexibility of the roof plane, with the uniform thickness. I am trying to taper the roof at the edge. any ideas? Thanks
Try creating a profile to use as your roof sweep for that one side. It could start at 16" and taper to the 6" at the 4 foot overhang.
I used Swept Blend tool and the geometry is working now but I have lost all the material layering ability of a normal roof (it seems I can only asign one material to the geometry). So does this mean I have to fake the section. I have attached the section Thanks!
If you are wanting to assign more than one material to your geometry used for your sweep, you might want to assign it the same material as your roof, but then use the paint feature to give the other parts a different look (I'm guessing you want the appearance of a facia? Otherwise, yeah, might have to find a way to "fake it". Filled Regions work well for that sorta thing... except I don't know how to make them parametric if there is such a way to do so.
Revit roof... truss vs. rafter |
Wed, Dec 18, 2013 at 11:26:23 AM
Problem with rafter cut |
Sat, Sep 4, 2010 at 3:44:19 AM
should roof rafter on top of the roof or under the roof. |
Tue, Jul 28, 2009 at 12:41:37 PM
Can't make a Two Cut - Square rafter cut on a roof |
Fri, Jan 14, 2011 at 6:20:31 PM
Get Roof Soffit To Have Same Rafter Cut As Roof? |
Wed, Jul 16, 2014 at 7:37:36 AM
Members: | 2097139 | Objects: | 23163 | Forum Posts: | 152288 | Job Listings: | 3 |
