60 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> structural usage for stacked walls
Sat, Jan 2, 2010 at 7:02:39 PM | structural usage for stacked walls
col9000
Hi
I've found that 2 walls will not join cleanly when they have different "structural usage" settings. Even if the geometries of the walls are joined, you can see a line at the joint in elevatio. This is fine for most of my walls, since I've changed the structural usage of them all to "bearing". However, I don't know what to do with the stacked walls, as they don't seem to have a "structural usage" dialog in under object properties. Anyone know how to fix this?
Thanks, and happy new year!
Colin
Tue, Jan 5, 2010 at 7:41:06 PM | structural usage for stacked walls
col9000
Hi,
Just refreshing this in the hope that someone might see it...!
Thu, Feb 25, 2010 at 3:24:13 PM | structural usage for stacked walls
jnovella1520
Hello,
Sorry in advance if this doesn't help, just throughing some thoughts out.  Are you not wanting to see the line down the wall were they don't join in elevation?  You could use the linework tool and change the line to invisible in elevation.  Also have you tried the Wall Joins tool to see if that fixes it?
Tue, Jun 15, 2010 at 5:03:16 PM | structural usage for stacked walls
MLB24
If you select the basic walls that the stacked wall is made of, do a "select all instances" and change it to bearing.  Then the stacked wall seems to take on the bearing wall properties.  I have only tried this in 2011 with the "select all instances in entire project" option.  Hope this helps
Tue, Jun 30, 2015 at 5:43:03 PM | structural usage for stacked walls
VeeTeeF
Thanks MLB24, that saved me a lot of time!!
Tue, Jun 30, 2015 at 5:54:01 PM | structural usage for stacked walls
VeeTeeF
Oh, I did this in Revit 2015 and it worked fine.
Tue, Jun 30, 2015 at 6:44:51 PM | structural usage for stacked walls
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
There is no need to ‘select all instances’. Just hover your mouse over the stacked wall and tab until single basic wall is highlighted, select it and change to structural.
Tue, Jun 30, 2015 at 6:48:09 PM | structural usage for stacked walls
VeeTeeF
That's true, but I needed to change all exterior walls in a model to structural combined and I was doing so one at a time which was beyond tedious. I didn't even think about selecting all in the project, it saved me hours.
Tue, Jun 30, 2015 at 6:59:57 PM | structural usage for stacked walls
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Never mind then. If you want to change them all, selecting all instances is the way to go. I just thought you wanted to change only one instance – the part of the stacked wall.
stacked walls
Tue, Nov 25, 2014 at 5:51:11 PM
Stacked Walls
Mon, Mar 31, 2008 at 7:53:12 AM
structural usage
Tue, Dec 16, 2008 at 10:14:42 AM
stacked walls
Mon, Sep 10, 2018 at 9:55:15 AM
Problems with Stacked walls
Mon, Dec 21, 2009 at 3:01:21 PM
Page generation time: 0.6305
