118 Users Online (117 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Tag dimensions to reference plane in 2010
Sat, Jan 2, 2010 at 2:56:32 AM | Tag dimensions to reference plane in 2010
ale02
ale02 Avatar
3 Stars: 3 Votes
Hi all,
Seems like tagging dimensions over reference planes is nomore available in 2010. or am i wrong?
Don't really have much time to explore 2010 ribbon interface but it definitely slow down my speed, guess have to look into shortcut keys as I reckon that is a good way to change my work of working revit in the future rather than icon based.
A good tip will be much appreciated...thanks in advance
Life is never easy but nor it should be complex. Just stay simple Smile
Sat, Jan 2, 2010 at 8:12:56 AM | Tag dimensions to reference plane in 2010
4 Stars: 202 Votes
Ale02, what do you mean with "tagging dimensions over reference planes" ???
Sat, Jan 2, 2010 at 10:06:48 AM | Tag dimensions to reference plane in 2010
ale02
ale02 Avatar
3 Stars: 3 Votes
What I really mean is putting dimension over reference planes and use them as construction lines or something
Used to do that mainly to equal divisions so I can copy things such as windows/ stiffeners equally to distance or between columns.
Seems like that does not work in 2010
Sun, Jan 3, 2010 at 7:30:50 AM | Tag dimensions to reference plane in 2010
4 Stars: 202 Votes
Ale02, i really don't see any problem with dimension in ref. planes in 2010, it's the same in 2009....
Sun, Jan 3, 2010 at 10:59:51 AM | Tag dimensions to reference plane in 2010
erland73
erland73 Avatar
4.5 Stars: 85 Votes
"Don't really have much time to explore 2010 ribbon interface but it definitely slow down my speed, guess have to look into shortcut keys as I reckon that is a good way to change my work of working revit in the future rather than icon based."
 Take a look at this:
http://bimboom.blogspot.com/2009/08/gift-for-you-wrapped-in-nice-ribbon.html
Wed, Jan 6, 2010 at 10:31:26 AM | Tag dimensions to reference plane in 2010
ale02
ale02 Avatar
3 Stars: 3 Votes
guys...thanks for the tips...
managed to solve the issues as I was clicking linear insteads of aligned dimensions..
I am pretty much of an acad user and think as an acad user too...
btw, what the different between aligned dimension with linear dimension..seems like linear dimension cannot impose on reference plane...
Wed, Jan 6, 2010 at 1:41:42 PM | Tag dimensions to reference plane in 2010
cobblea
Regarding the change to the 2010 ribbon,  try looking at this website:
http://www.nichitecture.com/downloads/Where%20is%20my%20command%20in%20Revit%20Architecture%202010.html
It was very useful to me when I was trying to find a tool in the new format back when we first made the switch from 2009.  After some time, I have gotten more used to the ribbon, even if it is a bit clunky.  Another handy trick is to right click on some of your commonly used tools (once you find them), and then "Add to Quick Access Toolbar". Any tool that you assign like that will always remain visible no matter which tab is active at the moment.  Keyboard shortcuts help quite a bit too.
Good luck with the switch!
Thu, Jun 11, 2009 at 10:45:44 AM
Reference Plane Dimension
Sat, Aug 20, 2005 at 7:33:46 PM
Manipulating Reference Plane in Family Type
Fri, Jul 25, 2008 at 6:18:26 AM
Wrong Reference plane flexing [ 1 2 ]
Wed, Sep 23, 2015 at 8:22:57 AM
23
Detail callout tag... for 2010
Wed, Nov 11, 2009 at 11:58:51 AM
Page generation time: 1.4439
