Forums >> Revit Building >> Technical Support >> Revit Fatal Error
2 Posts No Rating |
I am working on project using Revit Architecture 2010 and Revit Structure 2010. Everything was working fine until I started to modify a wall in Revit Structure and I got the following error: A fatal error has occurred. The application will be terminated. You will be given the opportunity to save recovery files for all of your changed projects. I made the recovery file and sent the error report to Autodesk and was offered the following fix: Autodesk Revit Structure 2010 Hotfix 2 Well, the link to hotfix 2 was broken, so I searched for it and found it, but the readme said that I needed to make sure that Upgrade 2 was already installed prior to installing the hotfix, so I followed the link to the upgrade - whose installation failed twice. Finally I was able to download and install the upgrade and then I downloaded and did the hotfix, but to no avail. I have tried using Revit Architecture to modify the wall or even delete it, but the very same process occurs "fatal error..." then hotfix 2...I can't modify this wall in either program without a fatal error occuring. I'm on a deadline and I need to be able to work on the project both structurally and architecturally, any ideas?
3 Posts No Rating |
We have had this happen several times at your firm. It only happens with Revit 2010 so we went back to using Revit 2009 until this issue is resolved.
16 Posts No Rating |
Make sure that you have updated your 2010 to the latest service pack and fixes for the wall bugs. I know service pack 2 is out, and it also has a seperate fix for the walls, check Autodesk for more details. This is a known issue.
2 Posts No Rating |
Well, this project was started in 2009 and while I did save a 2009 file that I could go back to, I would be losing a considerable amount of work if I did that, plus it's a work-share project so there's simple too much 2010 progress to go back. Although, these types of issues will certainly impact the decision on whether to do a porject in 2009 vs 2010. Checking the updates is definitely critical, especially since I learned there can be compatibility issues even from having two different updated builds/versions of the same year of software. In my case it wasn't a version issue since everything was working off of the newest releases.
In addition to the wall edit problem, Revit has a memory leak and will fill available memory over time. If you are on subscription and have loaded the advantage package, run the add-on for workshare monitoring. There is a system performace tab where you can monitor your memory usage and close when it is getting into the red area before it bombs. That tab can be set to trnsparent and left on top of your work.
1 Posts No Rating |
I had a similar problem, solved with update videocard driver try !
----------------------------------- Enjoy the silent |
Fatal error on a shared job Revit 2015 |
Tue, Mar 15, 2016 at 1:06:33 AM
fatal error |
Wed, Aug 30, 2006 at 1:15:23 PM
Fatal error when in any type of sketch mode |
Wed, May 16, 2018 at 11:28:44 AM
Fatal Error when adding casework tag |
Mon, Apr 6, 2009 at 12:38:41 PM
'Ungroup' causing fatal error in Revit Architecture 2011 [ 1 2 ] |
Tue, Aug 24, 2010 at 4:03:22 PM
15
Members: | 2102404 | Objects: | 23173 | Forum Posts: | 152296 | Job Listings: | 3 |
