184 Users Online (182 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Stacked Wall Flipping to other side... help please
Wed, Dec 30, 2009 at 7:37:20 AM | Stacked Wall Flipping to other side... help please
MARS1276
1 Stars: 1 Votes
Using Revit Building 2010
OK, I now have some experience with drawing stacked walls!  I did encounter a problem however.  When I used the 'draw wall by face' tool (somewhere under 'Massing and Site' tab) it would draw fine if you did the 'chain-select' option.  But even then, every time I 'break up' a stacked wall, the upper part of the wall "flips" on itself and you now have the inside of the wall facing the outside; totally off of the wall beneath it as well!  So this can be fixed easily enough by going to plan view and selecting the "flip" arrows next to the wall.  What I want to know is, how can this issue be resoved WITHOUT having to do that extra step?
Edited on: Wed, Dec 30, 2009 at 7:37:52 AM
stacked wall line visable on the wrong side?
Wed, May 6, 2009 at 10:51:59 AM
Wall sweeps flipping to inside face of wall (Revit 2013)
Wed, Jul 3, 2013 at 9:13:17 PM
Breaking apart a Stacked Wall Issue
Wed, Mar 11, 2009 at 12:03:45 PM
2013 - Stacked wall problems
Thu, Dec 12, 2013 at 8:23:40 PM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed
Thu, Jan 24, 2013 at 8:06:07 PM
Page generation time: 2.7439
