59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> 3d model shows wireframe while in shaded mode
Tue, Dec 29, 2009 at 2:36:54 PM | 3d model shows wireframe while in shaded mode
Warchitect
4 Stars: 5 Votes
Someone help me figure out why my 3d view is screwed up.
Check this screen shot ive tried everything I can think of to get it to display properly...still it gets on this wire frame while in shaded with edges mode.
any help would be greatly appreciated.
M
Tue, Dec 29, 2009 at 2:40:03 PM | 3d model shows wireframe while in shaded mode
Warchitect
4 Stars: 5 Votes
Figured out the bug, no responses necessary
Wed, Dec 30, 2009 at 6:35:44 AM | 3d model shows wireframe while in shaded mode
4 Stars: 203 Votes
You should post here the answer for the other guys with the same issue.... Pick in the 3D view button to "refresh" the view OR delete that 3D view and create a new one....
Also, you should post what version of Revit are you working AND if you did the upgrades (Web Updates) to that version....
Wed, Dec 30, 2009 at 2:25:44 PM | 3d model shows wireframe while in shaded mode
Warchitect
4 Stars: 5 Votes
Your right on the posting sorry. Revit 2009
The refresh didn't work. only deleting the view and restarting it.
Also, I tried to delete this post because I had discovered someone else had asked the Q, but couldn't.
Mon, Oct 3, 2011 at 2:48:01 PM | 3d model shows wireframe while in shaded mode
srad600
Sorry to revive and old thread, but I figured it's better to ask the same question in an old thread than in a new one.
So I'm running Revit Design Suite 2012 with the latest e-mail update patch installed (received it about two weeks ago). It seems that after this latest patch I am getting random 3D view types where portions of the smae view are wireframe and portions are whatever the view is actually set to. It does not update if I re-create the view or if I shut down and re-start. Actually newly created views open up in this manner. The only view type where this does not occur is when the view is set to realistic. All other settings are mixed. I'm hoping someone in the know may have a work around for this issue?
Thanks in advance.
Mon, Oct 3, 2011 at 4:14:54 PM | 3d model shows wireframe while in shaded mode
srad600
As is always the case, as soon as I post a question, I figure out the answer.
Just in case others follow my mistake, my problem was this: I created a wall type with a paint finish. The paint was set to be semi-transparent. Even though all of the remaining wall type layers were solid, the walls appeared transparent when viewed in 3d. Once I set the paint layer back to solid, all of the walls appeared solid.
Seems like the solid layers behind the paint should have made the walls appear solid, but they do not.
Mon, Oct 3, 2011 at 4:27:33 PM | 3d model shows wireframe while in shaded mode
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
you can have your render material semi-transparent and your grpahics/shading to no use render apperance for shading and just make it solid.
Revit model half shaded half wireframe
Mon, Dec 2, 2013 at 11:30:04 PM
Shaded wall in Wireframe
Mon, Jul 21, 2014 at 7:54:30 AM
Look at this wireframe model made in 3Ds
Sun, Apr 26, 2009 at 3:52:53 PM
Beams in 3D view shows only one line, not the whole volume !
Mon, Sep 8, 2014 at 12:13:25 PM
Showing Underlay Plan
Mon, Mar 21, 2005 at 11:09:00 PM
Page generation time: 2.3130
