55 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> View Range with Brace Frames
Wed, Dec 23, 2009 at 10:00:04 AM | View Range with Brace Frames
bazar
bazar Avatar
I am working in Revit Architecture 2010, but I think my question deals with Revit Structure. I am having trouble controlling the cut level of brace frames in plan. When I change the view range in plan, the cut plane changes, but the brace framing is not affected. I thought it was a link issue, but when I opened the structural revit model I noticed the same issue. The reason we need to have the brace frame cut at the correct level is so we don't show brace frames go across doors & opening. Any help is appreciated...
Wed, Dec 23, 2009 at 12:00:51 PM | View Range with Brace Frames
bazar
bazar Avatar
I was able to figure it out on my own:
For a column family, you can select the option Show family pre-cut in plan views, in the Family Category and Parameters dialog. When you select this option and load the family into a project, the column displays in a plan view using the cut plane specified in the plan view of the family.
  1. Open a column family or start a new column family.
  2. Click Create tab>Family Properties panel>Family Category and Parameters.
  3. In the Family Category and Parameters dialog, under Family Parameters, select or clear the parameter, Show family pre-cut in plan views.
Edited on: Wed, Dec 23, 2009 at 12:03:05 PM
View Range for Revit Link
Thu, Nov 12, 2015 at 7:10:18 AM
x brace frame
Wed, Dec 23, 2009 at 1:39:55 PM
Brace that goes through a girt. Best way to break the brace?
Fri, May 10, 2013 at 11:29:35 AM
X-brace in plan view help (new)
Mon, Jul 13, 2009 at 1:39:14 PM
brace display in plan view
Wed, Feb 4, 2009 at 3:34:34 PM
Page generation time: 1.5814
