81 Users Online (80 Members):
Forums >> General Discussion >> Revit Project Management >> Multiple Users and Worksets
1 Posts No Rating |
We have two users working in seperate worksets (ex, slabs and columns). Even when one user is working in the slabs workset, Revit 2010 will not always allow editing in the columns workset without having the other user syncronize with central, relinquish all theirs, and the other reloads latest. Nobody has ownership of the worksets, and REVIT is running very slowly. Is there a way to fix this issue?
If your worksets are set-up correctly- all slabs are assigned to the slab workset, and all columns are assigned to the columns workset- here's an idea: Open only the worksets required for your work. In this case, the other information is not ever loaded, and cannot be accidentaly owned or borrowed. On the Open button there is a small pull-down- you can specifiy which worksets you will open. Also, if you have large projects in which users will be assigned specific tasks- take the time to think about how you would like to break work-sets up.
Multiple User Worksets |
Wed, May 14, 2008 at 1:42:54 PM
Worksets |
Fri, Apr 14, 2006 at 3:07:09 PM
Groups & Worksets |
Sat, Dec 15, 2018 at 9:00:15 PM
Multiple users |
Thu, May 26, 2005 at 6:56:49 PM
Revit 2013 - File Structure Standards Multiple Users |
Mon, Mar 4, 2013 at 12:09:14 PM
Members: | 2030550 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
