45 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Tips & Tricks >> Help, Can't cut void geometry into a revolve dome-like solid
Wed, Dec 23, 2009 at 9:03:51 AM | Help, Can't cut void geometry into a revolve dome-like solid
hperez
I'm trying to a void throughout a dome-like revolve solid, but as soon as I finish the sketch I get a message saying that 'Can't keep elements joined.'At this point the option I get is to 'Unjoin elements'; same thing happens if I use the 'Cut Geometry'. I've tried changing the "profile sketch" on my revolve and noticed the problems only happens when the arc segment to generate the "dome" is introduced.Can Revit cut voids throughout dome-like revolve?Is this a Revit limitation?
Wed, Dec 23, 2009 at 9:11:22 AM | Help, Can't cut void geometry into a revolve dome-like solid
hperez
I'm now attaching the right images. Kind of new posting on Revitcity, sorry for that.
Wed, Dec 23, 2009 at 9:11:27 AM | Help, Can't cut void geometry into a revolve dome-like solid
hperez
Nested void geometry doesn't cut host solid
Mon, Dec 6, 2010 at 3:18:43 PM
using revolve tool to shape top of walls 'Revit 2012'
Wed, Feb 20, 2013 at 2:47:55 PM
Tapered and revolved solid form
Tue, Apr 10, 2007 at 8:12:10 AM
Void Sweep won't cut extrusion
Fri, Aug 24, 2012 at 3:02:42 PM
Void Masses
Fri, Oct 3, 2008 at 4:11:06 PM
Page generation time: 1.2638
