Forums >> Revit Systems >> Technical Support >> How do you change a "generic model" family into a "mechanical equipment" family?
11 Posts No Rating |
I have created a few families as "generic models" and I need to change them to "mechanical equipment" The families have duct, pipe, and electrical connections. I'm Really trying to avoid redrawing them.
Nevermind... I just answered my own question.
You should put the answer here for the other guys with the same problem.... Settings>Family category And Paarameters> Select the Category you want)....
0 Posts No Rating |
What about for a modeled in place family? I'm not seeing how to make that solution work in that case.
0 Posts No Rating |
Never mind, this basic method does work. I'm using a newer version of Revit than was available at the time of the original posts, so that might account for the minor difference.
I selected the model, clicked "Edit In-Place", then clicked "Family Category and Parameters" which is under Modify>Properties.
Possible to change Family category to "Roof" |
Mon, Aug 12, 2013 at 2:32:37 PM
How to make a "Model in-place" a "Family" |
Thu, Mar 17, 2011 at 5:08:00 PM
changing the "family" and "type" names |
Mon, Apr 2, 2007 at 5:33:50 PM
tagging by "family name" and "family type" |
Mon, Jun 1, 2009 at 8:54:55 PM
Annotations nested inside a wall hosted equip family: Cant see the annotation |
Wed, Aug 20, 2008 at 6:37:32 PM
Members: | 2099075 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
