41 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Slab Edge Visiblity Issue?
Mon, Dec 21, 2009 at 6:07:26 PM | Slab Edge Visiblity Issue?
rex916
So I created a slab edge profile of a closure plate and added it to the end of my elevated slab. When I place the profile, I get a warning saying "one element is completely inside another." After this I choose the option to unjoin elements. This works and it draws my profile in section, but when I go to the upper level (plan view) I see my closure plate as a dash line. I don't want to see the dash lines up above. Any ideas of whats going wrong?
Tue, Dec 22, 2009 at 6:34:09 AM | Slab Edge Visiblity Issue?
3.5 Stars: 395 Votes
You need to add some images so we can understand what you are doing.  An image of your profile in the family editor may help too.
Tue, Dec 22, 2009 at 12:17:15 PM | Slab Edge Visiblity Issue?
rex916
I attached an image file showing what is going on. First image you will see is a plan view looking down from level 2. The floor plan has 4 walls and a roof deck. Second image is a section cut and it shows my closure plate. Any help would be great.
Tue, Dec 22, 2009 at 6:10:09 PM | Slab Edge Visiblity Issue?
Aksha
In the Plan View, hide the slab edge. If you really have to be very accurate, create two slab edges- one vertical and one horizontal. Hide the horizontal slab edge in plan view.
Slab edge profile not available
Tue, Nov 10, 2009 at 1:56:29 PM
"Could not create Slab Edge"
Tue, Feb 17, 2009 at 1:40:42 PM
RC upstand on the edge of an RC slab
Thu, Jul 14, 2011 at 11:04:56 AM
Slab edge and abc confrontation
Wed, Dec 21, 2011 at 2:31:44 PM
Revit 2010 Slab Edge Trouble
Mon, Feb 15, 2010 at 8:54:39 AM
Page generation time: 0.8107
