46 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> How Large Can A Rendering Be Blown Up?
Mon, Dec 21, 2009 at 12:47:04 PM | How Large Can A Rendering Be Blown Up?
albertstwrt
4 Stars: 8 Votes
What is the largest size you can increase a ReVit Rendering too?I'v send one out to a print service to be inlarge to 24" x 36" and the rendering pixelated.
The size of the rendering was 1170X640.
Wed, Dec 23, 2009 at 7:52:08 AM | How Large Can A Rendering Be Blown Up?
MARS1276
1 Stars: 1 Votes
Can you copy the rendering as a PDF file format?  If it pixelates when enlarged, that means it is a Raster image.  PDFs use Vector lines.  With PDFs, what you see is what you get (unless your printer can't handle the dimensions you want).
Fri, Jan 15, 2010 at 2:10:26 PM | How Large Can A Rendering Be Blown Up?
lunchtrayrider
3.5 Stars: 7 Votes
when rendering you want to set your view size to the size you want to print it at e.g. 24"x36".  this is located in your options bar.  then select the dpi that you want to have the print at.  300 is good for really high quality images.  this is going to be huge however.  you might do 150 dpi so it doesn't take a lifetime to render.  the difference is an image that is 7200x10,800 or 3,600x5,400.  Revit won't print a rendering as a vector drawing.  a rendering is a raster image and cannot be converted to a vector drawing with the results that you expect.
Large Format Rendering
Wed, Jun 27, 2012 at 6:30:52 PM
Rendering a LARGE image
Mon, Nov 23, 2015 at 7:50:18 AM
Complete Rendering
Tue, Mar 27, 2012 at 6:12:31 PM
Rendering - Tame the Sun
Fri, Jun 4, 2010 at 4:36:35 PM
large format rendering
Thu, Oct 22, 2009 at 8:44:34 AM
Page generation time: 0.4424
