31 Users Online (30 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> family with array question
Mon, Dec 21, 2009 at 11:42:33 AM | family with array question
col9000
Hi,
I'm modelling a building with lots of sections of vertical timber louvres. I've like to make a family that is a plane of louvres that I can stretch both horizontally and vertically. The vertical bit is easy, as it just involves the louvres getting longer.
Is it possible to stretch such a family horizontally so that when the panel of louvres becomes wider, more louvres appear (and the size and spacing of the louvres remains constant?
Would appreciate any help thanks!
Col
Tue, Dec 22, 2009 at 6:34:31 AM | family with array question
4 Stars: 203 Votes
Look this tutorial from Mr. Spot, maybe it help you: http://www.revitcity.com/tutorials/arrays_and_nested/
Family w/ Array Formula
Fri, Mar 23, 2007 at 9:29:38 AM
Radial Array in a Family
Mon, Apr 11, 2005 at 8:56:13 PM
Associated Parameters in Array Family
Mon, Feb 27, 2017 at 8:44:37 AM
Array Parameter within Family
Thu, Aug 7, 2014 at 8:25:10 AM
Parametric Array Constraints
Tue, Jul 2, 2019 at 7:00:46 AM
Page generation time: 1.2236
