101 Users Online (100 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Rendering problem (dots)
Sat, Dec 19, 2009 at 9:09:55 AM | Rendering problem (dots)
xzavoral
Hi!
I have problem with rendering in Revit Architecture 2010. I used predefined "medium" settings but this came out:
White dots from light. How can I fix this?
thx for help
Sat, Dec 19, 2009 at 8:02:08 PM | Rendering problem (dots)
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Reduce the reflectivity and tone down the bump mapping.  They also will resolve themselves if you render at higher quality settings...
Regards,
Chris.
Sun, Dec 20, 2009 at 1:47:35 AM | Rendering problem (dots)
xzavoral
This material has only brightness (i didnt found reflectivity on this one)
Where can i edit bump mapping in materials?
Can it be problem that the image is not good pixel quality?
thx for help
Sun, Dec 20, 2009 at 2:57:36 PM | Rendering problem (dots)
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Try a region render at high or best quality first to see if it fixes the issue.  Its generally to do with the number of bounces for reflectivity in your render settings.  If the surface is bumpy it can take extra effort...
Regards,
Chris.
Sun, Dec 20, 2009 at 4:43:43 PM | Rendering problem (dots)
albertstwrt
4 Stars: 8 Votes
Spot, I have reduce the reflectivity in this scene, and the pew material color still reflect to the ceiling.
Mon, Dec 21, 2009 at 1:52:15 PM | Rendering problem (dots)
xzavoral
I'm rendering at High at 600 DPI in office ower night so will se the result tomorrow ...
Is there some good GUIDE hwo to render in revit 2010 ? I would love to make photorealistic images
at work:
Intel Quad Core 4x 2,3 GHz
4 GB Ram
but the render goes too slow compare to 3ds Max where fotorealistic render is about 30 minutes or 1 hour max ... Sad
Any help there from Autodesk or other programs/options ?
Tue, Dec 22, 2009 at 6:43:15 PM | Rendering problem (dots)
xzavoral
The result looks good at High, but it rendered whole night.
I saw Artlantis released addon for Revit to Save files for him and than render them in Artlantis ... will it be faster ? (how much faster?)
Any experience someone with Artlantis rendering ?
Sun, Dec 27, 2009 at 5:10:18 AM | Rendering problem (dots)
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Interior renderings in Revit are somewhat slow as generally for interior renderings high detail is required and also artificial light sources which slow things right down.
The difference between rendering an identical image in Revit on a quad core pc to Max would be neglible.  They use an identical rendering engine.  Max is streamlined a little better so might finish about 5% faster.
You can achieve results quicker in max because you have more control over the rendering settings and can "fake it" if you know what you're doing.  It can also take advantage of more processors or render farms using Backburner...
Zachary Kron posted some interesting figures on what materials take the longest to render so you may wish to check out his blog "buildz".  I've managed to produce some very realistic images in Revit, but generally they've taken upwards of 48 hours of processing to complete.  It's also a good idea to just render the screen resolution rather than a printer resolution...  This gives faster results and most screen resolutions these days are good enough for a decent size print if needed.
I haven't used Artlantis, but Vray seems to be the architectural render of choice for most these days...
HTH.
Regards,
Chris.
Thu, Dec 31, 2009 at 12:00:28 PM | Rendering problem (dots)
xzavoral
But the V-ray can be used only in Max, or is there any way to use it in Revit?
I need high resolution images for A3 printed images on photo pape, so I need really high resolution because its mostly interier ...
blue dots in linework
Wed, Aug 18, 2010 at 4:13:09 AM
Rendering Revit Architecture 2009 - Little Black dots!!!!
Fri, Dec 19, 2008 at 5:42:49 AM
*Red Dot Problem When Rendering*
Sun, May 3, 2015 at 3:49:56 PM
Wall host layers - strange dots
Tue, Nov 19, 2013 at 3:26:55 AM
Rendering on Revit 2012
Mon, Feb 18, 2013 at 4:29:20 AM
Page generation time: 1.5416
