68 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Cutting Sections through imported Autocad 3d objects
Fri, Dec 18, 2009 at 11:35:02 AM | Cutting Sections through imported Autocad 3d objects
molafamilia
I'm wondering if anyone knows how cut a section through an imported autocad 3d object. when i go to cut a section through i only get end views of the object. i included a project i'm working on so you can see what i mean.
Fri, Dec 18, 2009 at 12:39:54 PM | Cutting Sections through imported Autocad 3d objects
Read your help using cuttable as your search.  You will see tghat only some categories are cuttable.
Converting AutoCAD ACIS Objects (3D Solid) to Polymesh Objects
Fri, Oct 12, 2012 at 7:31:59 AM
Improving Linework in Sections & Elevations
Sun, Mar 30, 2008 at 12:30:49 AM
How do I remove faceting from imported 3d objects?
Fri, Feb 22, 2013 at 7:26:41 AM
rendering imported objects
Tue, Mar 10, 2009 at 2:23:19 PM
Section or elevations not cutting imported dwg's
Fri, May 9, 2008 at 3:30:45 PM
Page generation time: 2.1688
