64 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> reverse view clipping...?
Thu, Dec 17, 2009 at 7:43:29 PM | reverse view clipping...?
col9000
Hi,
I've drawn a vertical pipe that has an offset at the second floor of my building. Unfortunately when I look at the ground floor plan I see the whole pipe, offset included, even though its way above. Is there a way of cutting this type of family? I've drawn it as a mechanical equipment family.
Thanks!
Col
Fri, Dec 18, 2009 at 6:43:30 AM | reverse view clipping...?
3.5 Stars: 395 Votes
Search for cuttable in your HELP and you will find your answer.
Is there a way to reverse the View Type Title?
Mon, Aug 22, 2011 at 3:26:46 PM
Far Clipping Stops working when I zoom in/ out of view
Wed, Jul 16, 2014 at 11:20:39 AM
11
Clipping Callout Bubbles when clipping View
Thu, Jan 3, 2013 at 6:24:11 AM
Diagonal Clipping
Mon, Jun 30, 2008 at 9:43:29 AM
Section cut with clipping
Wed, Mar 25, 2009 at 10:12:21 AM
Page generation time: 0.7272
