81 Users Online (81 Members):
Forums >> Revit Building >> Technical Support >> 64 bit screensaver crash
I am using R2010 on a 64 bit XP machine. It's been pretty stable so far, with the exception of the screen saver. If the screen saver starts while Revit is running, it will crash 99% of the time. Sometimes I can save-as, most of the time Revit is just gone. Has anyone else had this problem, and if so have you been able to fix it?
136 Posts No Rating |
LCD displays don't need a screen saver, just disable it. (i assume since you say you have a 64 bit machine that your not running an antique CRT monitor) If you must have a screen saver then i suggest trying a simple OEM one and not some picture filled thingy you downloaded
I'd rather be riding at whistler. or highland. thats good too.
I am unfortunately running an antique as a secondary monitor. I don't use anything special for a screensaver, just one of the standard windows ones. I do have the time set fairly high, so I try to remember to just shut down Revit if I think I'm going to be away from my desk that long. But if I forget, it'll shut itself down when I get back. It's not really a big issue, just wondering if anyone else has had it.
Crash!!!! |
Thu, May 5, 2011 at 4:09:10 PM
A required resource was unavailable. Crash on 32 bit Operating System |
Wed, Jul 14, 2010 at 6:12:03 AM
2010 and vista 32-bit |
Thu, May 7, 2009 at 10:40:48 PM
11
windows XP Professional x 64 bit |
Wed, Sep 27, 2006 at 12:39:51 PM
crash recovery |
Thu, Apr 23, 2009 at 7:02:48 PM
Members: | 2030567 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
