158 Users Online (157 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Callout tags refencing same view
Wed, Dec 16, 2009 at 8:20:09 PM | Callout tags refencing same view
BiggieP
I have two sections that call out thw same parapet detail.  I have linked both callouts to the correct detail view.
I was hopeful that placing the detail would have the tags change in both locations, but this does not seem the case.
 Has anyone has this senario before?
 thanks
Thu, Dec 17, 2009 at 3:09:24 AM | Callout tags refencing same view
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Have you used "Reference Other View"?  If so, then the callout tag references should be correct in both of them...
Regards,
Chris.
Callout tags
Thu, May 1, 2008 at 11:39:20 PM
12
room tags in sheet view
Thu, Jun 8, 2006 at 9:35:24 AM
Room tags in callout views.
Thu, Jun 28, 2007 at 4:30:53 PM
Duplicating callout views...??
Wed, Oct 28, 2009 at 10:18:11 AM
CALLOUT DETAIL VIEW VS. PLAN VIEW
Wed, Mar 10, 2010 at 2:04:47 PM
Page generation time: 0.8909
