80 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Wall Sweep Setback
Wed, Dec 16, 2009 at 11:15:51 AM | Wall Sweep Setback
cadman7577
1 Stars: 1 Votes
I'm using Revit 2010.  Standard wall sweeps which come with the program.  For the life of me I can't figure out how to get the Brick Soldier course to properly sweep.  When I load ths sweep it applies it to the face of the wall.  The "setback" variable appears not to be doing anything.  Am I missing something?
Wed, Dec 16, 2009 at 12:44:38 PM | Wall Sweep Setback
3.5 Stars: 395 Votes
Spend some time in your HELP understanding profiles.  Also look at the profile template.  For hosted profiles, like wall sweeps, you will see there is a designated face and depending on how your sweep is made, your "offset" may need to be a negative number.
Wed, Dec 16, 2009 at 12:58:14 PM | Wall Sweep Setback
cadman7577
1 Stars: 1 Votes
Hey thanks.  I guess I assumed the templates that were packaged with Revit would have been done correctly.  Got it working now.
Wed, Dec 16, 2009 at 1:00:54 PM | Wall Sweep Setback
They are done correctly.  They don't know you want the sweep imbedded.
Wed, Dec 16, 2009 at 1:12:36 PM | Wall Sweep Setback
cadman7577
1 Stars: 1 Votes
Well that is the only problem I have seen with Revit thus far.  Programers working on Architecture.  Not sure how you construct a wall with a Brick Soldier course slapped to the exterior face of a wall and not imbedded.
Anyway thanks for the help.
Wall opening setback for door jamb
Tue, Apr 30, 2013 at 8:43:06 AM
how can I make an arc setback in a revit wall, not openings.
Mon, Oct 25, 2010 at 1:26:48 AM
Wall sweep won't trim
Tue, Apr 25, 2017 at 2:07:17 PM
Repeatig wall sweep vs. repeating detail - wall attached [ 1 2 ]
Sun, Dec 7, 2008 at 3:51:44 PM
19
How to Load a Wall sweep type
Mon, Jun 9, 2008 at 12:42:29 PM
Page generation time: 1.9226
