Forums >> Community >> Newbies >> Scalable break lines
9 Posts No Rating |
When drawing details or sections - in Revit is there a way to insert a break line to show the cutting of the drawing. Have been manually drafting in the lines and would like to know if thre is an easier more efficient/scale driven way to do this. Any suggestions appreciated. P
You will find the breakline under detail components. The item is fully adjustable after placement. BTW ... If you look at the similar threads shown below or searhed the forums, you would have found this same response. | | | \/
9 Posts No Rating |
looked in my detailed components but came up empty - nothing relating to breaklines - is it labeled something other than what I am expecting to see? It should be an out of the box detail component yes?
should be under Detail Components => Div-01 General hth
9 Posts No Rating |
Never would have found it - much thanks GO REVIT!
Detail/ Break lines |
Mon, Apr 29, 2013 at 4:02:35 PM
View Breaks and break lines |
Tue, Jun 26, 2012 at 6:49:55 PM
Break lines sizes. |
Mon, Mar 2, 2009 at 2:15:32 PM
Stair Elevation with break lines |
Tue, Mar 23, 2010 at 2:19:30 PM
Break Grid lines |
Sun, Jul 18, 2010 at 9:36:15 AM
Members: | 2116495 | Objects: | 23196 | Forum Posts: | 152302 | Job Listings: | 3 |
