159 Users Online (158 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Naming of local file!!
Wed, Dec 9, 2009 at 2:53:13 PM | Naming of local file!!
joshb
I am working in Revit 2010 and I was wondering if the name of local files matter for when you synchronize with central?
As for example......I have Revit installed on my computer with my name, we'll say JSmith.....so when i creat my local copy it gives me the file name of CENTRAL_JSmith
But i have recently gotten a new computer and my computer had been transfered to a different person in the office....even though his computer has his name, we'll say MRogers, when he creates a new local copy it still gives him the name CENTRAL_JSmith instead of using his name....any suggestions on why this is happening?
Thanks!
Wed, Dec 9, 2009 at 3:48:26 PM | Naming of local file!!
TKennedy
4 Stars: 7 Votes
You need to go to Options in Revit, and in the General tag there is a field for Username. By default it is filled out with the computer login name, but it can be changed to whatever you want.
Edit: That username does matter when it comes to syncing with the central file, it thinks that the same person is checking out the worksets. R2010 uses that username to automatically name the local file, but the local filename does not affect syncing with the central file.
Edited on: Wed, Dec 9, 2009 at 3:51:40 PM
Wed, Jul 31, 2019 at 3:22:44 PM | Naming of local file!!
hanbyjm
Our firm has one account for our Autodesk log-in for our subscription. We have to log on to this account to do updates and loading new programs.  When using Revit 2019 I was able to log on to my Autodesk account and open the program and save a local file with my account username.  After loading Revit 2020 I am not able to open 2020 when logged on to my Autodesk account. I now have to log in to the group account as do the others.  My question is can we all have separate local files with the same user name and still sync with the central file?
Mon, Feb 17, 2020 at 10:49:28 AM | Naming of local file!!
hanbyjm
Bump  Can anyone answer my question?  We are getting ready to start a project in Revit for the first time and am wondering if we are going to have problems worksharing.  Thank you.
Update:  Our admin never set up the users! Now we are able to log in under our user names.
Edited on: Tue, Feb 18, 2020 at 7:45:13 AM
Can not create local file from Central
Tue, Mar 6, 2012 at 11:57:27 AM
A local file enslaved to another local file? Is that possible?
Fri, Jan 8, 2010 at 5:06:16 PM
Local and Central File locations
Tue, Sep 12, 2006 at 10:04:33 AM
Storefront window in a local file won't relinquish and resave to Central
Tue, Mar 22, 2016 at 2:19:22 PM
Local files keep becoming incompatible with central file!
Thu, Oct 28, 2010 at 9:39:24 AM
Page generation time: 0.6437
