50 Users Online (47 Members):
Forums >> Revit Building >> Technical Support >> Stair visibility and room tags
2 Posts No Rating |
My stairs view correctly in plan until I place a room tag in the stair. Once the tag is in place, you can see the stairs below through the floor. Any suggestions on how to fix this? I am using Revit 2008.
Not sure what you are saying. An image may help.
2 Posts No Rating |
Here is the same stair. One view has the rooms and room tags visible (stairs appears through floor). The other view has the rooms and room tags hidden (stair appears correctly).
Vanishing room tags |
Tue, Sep 6, 2005 at 5:54:21 PM
Visibility Parameter in Room Tag |
Fri, Jun 4, 2010 at 6:01:09 PM
ROOM TAGS |
Fri, Jul 29, 2011 at 8:25:58 AM
Room Tags |
Wed, Nov 17, 2010 at 11:36:04 AM
Room Tags disappeared when 08 file saved in 09! |
Wed, Sep 10, 2008 at 1:11:22 PM
Members: | 2042244 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
