50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Surface Pattern of Material
Wed, Aug 31, 2005 at 4:25:34 PM | Surface Pattern of Material
remashiach
I am trying to show a stone wall and have assigned a surface pattern. However, this pattern shows up on elevations, section and on the dynamic 3d view but when I make a camera view the wall shows as black with no surface pattern showing the stones. How can I make the pattern show up in these views too? Pls help!
Wed, Aug 31, 2005 at 4:37:53 PM | RE: Surface Pattern of Material
TomDorner
4.5 Stars: 25 Votes
Chances are the black that you are seeing in the views is the surface pattern, but you are so far back in the view it all blends to black. Try zooming in to verify. You may need to adjust the scale of the pattern, the scale of the view or both to get it to suite your needs. Also remember that the surface pattern you see can be a model or drafting pattern. Model patterns are real world dimensions and drafting patterns adjust to the scale of the view. If you are going to render the view, then the surface pattern won't be used anyway but rather the material definition. HTH Tom
Wed, Aug 31, 2005 at 5:25:37 PM | RE: Surface Pattern of Material
remashiach
Thanks..... I got it now!!!!
Hiding Surface Pattern For Specific Wall Material
Thu, Feb 21, 2008 at 10:47:29 AM
Surface pattern
Mon, Sep 10, 2007 at 11:18:01 AM
View dependent material surface patterns
Wed, Apr 22, 2015 at 1:57:55 PM
Surface pattern to Topo surface
Mon, Aug 19, 2013 at 10:50:10 PM
Creation of a new Material Surface Pattern
Wed, Sep 21, 2011 at 6:43:53 PM
Page generation time: 1.0082
