36 Users Online (34 Members):
Forums >> Revit Building >> Technical Support >> Wall surface pattern by phase?
46 Posts No Rating |
I'd like just the new walls to have a visible surface pattern and the existing walls to be blank. Is it possible to control wall surface patterns by phase? Thanks and thanks to all the contributors here who are life savers with their input!
----------------------------------- Architect |
Yes. Go to Manage-->Phases-->Phase Filters Then set the projection pattern override for existing phases to not be visible. HTH.
Regards,
Chris.
Hi Chris, Don't you mean "Graphic Overrides" Tab not "Phase Filters"? If I uncheck the "Visible" box, then the floor and T-Bar ceiling grid patterns also disappear which is a problem... I just want to turn off the existing and just the wall surface patterns to differentiate between new and existing walls.... See the attachments
Surface pattern move/align/adjust problems [ 1 2 ] |
Thu, Sep 17, 2020 at 10:29:33 AM
19
Surface pattern to Topo surface |
Mon, Aug 19, 2013 at 10:50:10 PM
SURFACE PATTERN LINE WEIGHT |
Fri, Mar 28, 2014 at 2:30:00 PM
surface pattern visibility |
Fri, Sep 13, 2013 at 9:46:29 AM
Existing Phase Surface Patterns visibility |
Tue, Nov 14, 2006 at 6:37:24 PM
Members: | 2022352 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
