68 Users Online (66 Members):
Forums >> General Discussion >> Revit Project Management >> Project Templates - Title Block Concepts
20 Posts No Rating |
I am interesting in knowing what most people do with regard to setting up a company standard project template and your title blocks. We have a Schematic Design (simplified title block) and a Construction Document title block. Would you create two project templates; one with a SD title block, one with a CD title block OR would you have both title blocks in the template project? Any other creative ideas on project templates and their sheet setup? Thanks,Jeff
![4 Stars: 7 Votes](/images/stars_4.gif) |
Granted, I don't have as much experience with setting up templates as others on this forum, but I think I would just have both titleblocks in the template.
![Mr Spot Avatar](user_avatar/1073.jpg)
![4.5 Stars: 93 Votes](/images/stars_4.5.gif) |
Limit your number of templates. It makes things easier to manage and easier for your users. Plus you don't end up with a situation where users use the wrong template to start a project and then you have to transfer settings etc.
Regards,
Chris.
OK, so I limit my templates to one. What procedure would you suggest to move a project from Schematic Design (using a SD title block) to Construction Documents (using a CD title block)?
Remember, nothing is frozen in your file so there is no reason to try and maintain your SD sheets. Make a "hardcopy" of your SD - PDF's/DWF's? and I like to archive a copy of the central, then just start placing your views on new sheets or swapping the titlebocks as appropriate.
Good point...thanks.
In the default Revit Templates i couldnt find revit title block |
Fri, May 23, 2014 at 7:22:23 AM
Font on Title sheet absent from project Title Block |
Thu, Sep 15, 2022 at 12:31:26 PM
Revit templates |
Mon, Jun 28, 2004 at 6:49:33 AM
project title block |
Tue, Dec 1, 2009 at 2:18:45 PM
Title Block labels |
Sun, Apr 8, 2007 at 10:04:03 PM
Members: | 2022271 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
