61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> listing an arch model element in a structural model
Tue, Dec 8, 2009 at 3:31:21 PM | listing an arch model element in a structural model
Steve123
I'm new at Revit Structure so bear with me. In autocad there's an express tool command called "List Xref/Block Properties". It gives you the ability to find what layer a line has been drawn on even if the line is part of an xref. Is there a way to click on an element in an architect's model that has been linked into my structural model that will tell me what category that element has been drawn on so I can go to the visibility graphics window an edit it?
Tue, Dec 8, 2009 at 3:33:36 PM | listing an arch model element in a structural model
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Use your tab key.  You can tab down to select individual elements of a linked model.  Then simply look in your status bar or in the type selector to see what category it is.
Regards,
Chris.
Linking structural model to architectural model
Tue, Oct 9, 2007 at 6:05:11 PM
When I import REV. ARCH Link, it lands way outside my work space
Fri, Oct 9, 2009 at 12:22:40 PM
Arch Model
Thu, Feb 14, 2008 at 1:20:52 PM
ARCH Model and STRUCT Model in the Same File
Mon, Jul 13, 2009 at 6:49:42 AM
Joining Beams and Floors - Beams in a Structural Linked File
Fri, Jun 22, 2018 at 10:07:04 AM
Page generation time: 3.7543
