83 Users Online (81 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Stationing Grids and Dimensions REVIT Structure 2010
Mon, Dec 7, 2009 at 3:34:07 PM | Stationing Grids and Dimensions REVIT Structure 2010
LisetteTerry
LisetteTerry Avatar
Has anyone ever tried to use stationing labels for grids and dimensioning in REVIT Structure 2010?  I was hoping to create a parametric relationship between a stationing label and the shared coordinate system within the project.  Does anyone have any idea of how to accomplish this?
By stationing for example: 6X+500, 7X+000, 7X+500, 8X+000 etc...
The project is set up with a shared coordinate using state plane coordinates.  (Northing = some number and Easting = some number).  I want to relate one station point (1X+000) to that shared coordinate point such that when I dimension to any point or structure it will show as a stationing point (6X+232) as oppose to a length in meters.
My initial thought was to create a family that takes a dimension length from a reference plane and labels it as a station buy using a formula in the type parameters, however I am not quite sure how to write the formula to accomplish this.
Thank you for any help/advice.Lisette Terry
Life is not always linear...
Moving a Portion of a Building
Wed, Dec 14, 2011 at 10:49:58 AM
Dimensioning grids
Thu, Sep 21, 2006 at 9:50:35 AM
DIMENSIONing GRIDS - on plan view
Thu, May 26, 2011 at 1:33:20 PM
grids in 3D view
Fri, Dec 17, 2010 at 11:08:32 AM
Tag dimensions to reference plane in 2010
Wed, Jan 6, 2010 at 1:41:43 PM
Page generation time: 1.7208
