82 Users Online (81 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Multi Discipline Border
Mon, Dec 7, 2009 at 1:44:41 PM | Multi Discipline Border
patton
5 Stars: 2 Votes
I'm try to create a generic border that has multi disciplines using it (MEPS) and they all have the same location for their seal block.  I have tried creating shared parameters in the titleblock and then setting them up in the project but can't seem to figure out how to have one seal on for each discipline per sheet. When I fill in the info they all just lay on top of one another. It is like I need the yes/no option for each of these per page but can't seem to figure out how to set it up. Any thoughts anyone??
 Thanks
Mon, Dec 7, 2009 at 1:49:58 PM | Multi Discipline Border
TKennedy
4 Stars: 7 Votes
Select whichever objects you want to control with a parameter and open their instance properties. Under "Graphics" there is a parameter called "Visible", with a check box. All the way to the right on the same line there is a button, click it and it will open a dialoge box where you can pick a Yes/No parameter, or create a new one. Tie each different seal to a different parameter, then in your project you will have different check boxes when you go to the type or instance properties of the titleblock.
Sub Discipline under Views?
Fri, Apr 17, 2009 at 2:21:22 PM
Multi-Category Schedule with Links
Wed, Aug 10, 2016 at 6:23:57 PM
Can't find Sub-Discipline in Properties
Mon, Jan 27, 2014 at 5:24:23 AM
Controlling Display setting per Discipline
Fri, Feb 17, 2012 at 12:33:05 PM
How to change the name of discpline and sub discipline in revit project browser?
Tue, Jul 7, 2009 at 4:02:40 AM
Page generation time: 2.5263
