53 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> I can't see my Elevation View
Thu, Dec 3, 2009 at 11:15:30 AM | I can't see my Elevation View
ceastudents
Sorry if this is in the wrong forum, I wasn't sure where to put this in...
 Self-explanatory, I can't see my elevation views.  This isn't the first time that this has happened to me, but it's getting more and more annoying and...just plain bothersome. When I first open up a new project it's there, but after working a bit and when I realize I need to add another elevation level, the elevation views aren't there, I can't find it in the browser bar in the side and etc.  What's more, if I copy my design to a new project sheet, I get my elevation views, but then my 3D view disappears.
A little help? Anyway to bring my missing views back or am I doing something funky?
Thanks.
Thu, Dec 3, 2009 at 12:54:49 PM | I can't see my Elevation View
tim123
4 Stars: 19 Votes
If the elevations aren't showing in the browser then they must have been deleted, although Revit warns you before deleting an elevation.  If you go to a plan view look at the elevation marker (if you can't see it then unclick crop view or click on the bulb to reveal hidden elements).  The elevation marker has a box on each side.  The checked ones indicate where views are associated with it, so check one if they're all unchecked.  Click on the arrow to show the extents of the view, as the view may be cropping before your actual building.
You can get a new 3D view at any time by clicking on Default 3d view.
ELEVATION CALLOUT DOESN'T SHOW UP IN DETAIL VIEW
Mon, Jul 29, 2013 at 4:50:17 PM
Structural beam won't show in elevation
Fri, Aug 12, 2005 at 5:22:08 PM
Hiding View Name in Elevation View Tags
Fri, Jan 21, 2011 at 6:47:39 PM
Interior Elevation Tag
Wed, Dec 19, 2012 at 2:25:25 PM
can't see elevation tags in one view
Tue, Aug 30, 2016 at 1:34:14 PM
Page generation time: 9.9902
