83 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Stone patterns - "the pattern with the values you have supplied is too large"
Wed, Dec 2, 2009 at 12:45:16 PM | Stone patterns - "the pattern with the values you have supplied is too large"
chowlowhammond
Anyone else having problems with stone model patterns??  I downloaded the attached .pat file from here, but there are several patterns that show very small.
For example:  the pattern "SLSTN" cannot scale any bigger than 9.  At 10, I get this error message:
"The pattern with the values you have supplied is too large. Try decreasing the Line Spacing values"
I've tried changing the .pat file units from inches to mm but that was no help.
Any suggestions?  These are great model patterns, but I can't use them if the scale is unrealistic.
Wed, Dec 2, 2009 at 2:10:39 PM | Stone patterns - "the pattern with the values you have supplied is too large"
You are trying to load all the pats.... not just one.  You need to break out the pat file you want to load at a different scale.  Don't use the combined file.
Wed, Dec 2, 2009 at 3:34:32 PM | Stone patterns - "the pattern with the values you have supplied is too large"
chowlowhammond
Really?  When loading a .pat file with more than one pattern type, a list comes up & you're required to select the desired pattern from that list.  I tried isolating the SLSTN code into it's own separate file, & the same error message occurs.  The pattern will not scale bigger than a factor of 9.
I'm on Revit Architecture 2010.   Can anyone scale the SLSTN Pattern by a factor of 10 or larger?
 Thanks.
Wed, Dec 2, 2009 at 3:52:48 PM | Stone patterns - "the pattern with the values you have supplied is too large"
Your right, that file can not go to that scale factor.  We use a different one that is not as dense as that one. (Carolina ledgestone)
Mon, Dec 7, 2009 at 1:27:34 AM | Stone patterns - "the pattern with the values you have supplied is too large"
hugh
3.5 Stars: 4 Votes
The maximum scale on loading that pattern to to Revit is just under 9.57. With HatchKit you can scale up rather more Te attached file contains that pattern scaled up 20x. Load it to Revit at 1:1 scale.
Hth,
Hugh Adamson
Cadro Pty Ltd
www.hatchkit.com.au
Hugh Adamson
www.hatchkit.com.au
Stone Hatch Patterns - Looking for a good source.
Sat, May 4, 2013 at 4:59:25 AM
Editing Hatch Patterns
Tue, Apr 3, 2007 at 2:33:20 AM
Stone Pattern RAC V2009
Fri, Apr 25, 2008 at 10:30:16 AM
Fill Pattern- Dry Stack Stone
Tue, Dec 5, 2006 at 5:29:50 PM
Stone Hatch patterns
Fri, May 3, 2013 at 6:11:32 PM
Page generation time: 0.7536
