39 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> is "orient view to" gone in 2010?
Wed, Dec 2, 2009 at 8:18:39 AM | is "orient view to" gone in 2010?
ZSPTurbo
Yesterday my professor tried to show me how to make section cuts appear in 3d, but could not do so because in 2010 the "orient view to" command seems to have been removed. I have spent half an hour searching the forums, blogs, and help file, and have not been able to find any information... did they remove this feature completely?
Wed, Dec 2, 2009 at 8:30:16 AM | is "orient view to" gone in 2010?
marc
F8 or steering wheelright click and there it is
Wed, Dec 2, 2009 at 8:40:04 AM | is "orient view to" gone in 2010?
ZSPTurbo
Im so happy right now I could kiss you.... thank you so much. Now to figure out how to make feature behave for me :-D
Wed, Dec 30, 2009 at 7:28:53 PM | is "orient view to" gone in 2010?
emgeeo
3.5 Stars: 7 Votes
For every good thing they've done in 2010 there is probably at least one bad thing!
What the hell is Orient to View doing on the steering wheel?  Why can't I access it through the view ribbon?  It looks like I'll have to set up another keyboard shortcut.
Tue, Mar 8, 2011 at 3:24:12 PM | is "orient view to" gone in 2010?
iamian33
iamian33 Avatar
Greetings.
Further to this thread, AFTER I have used the 'orient to view' option, is there any way to change the Section Box back to a previous size?  I was hoping that I could associate the section box to a scope box but this is not an option.
If I uncheck the section box then re-check it, the secion box returns to the extent of the entire model/toposurface.
this is a great command (where ever it is located) but I would like to maintain a section box that shows the building model (and not the entire toposurface), orient to a view, when necessary ... and then return to my previous section box.
IanRAC 2011
Ian Shafer
Principal Consultant
True North S&F Consultants
Plan Render-No "View Size"?
Tue, Jan 13, 2009 at 4:25:22 PM
RevitMEP 2010 - Fixing Errors - "Check Duct Systems" + "Check Pipe Systems"
Fri, Sep 18, 2009 at 11:59:30 AM
{3D} view set to "Shading with Edges" looks like "Wireframe" with color...
Wed, Aug 12, 2009 at 7:05:46 AM
11
Ceiling Plan tags in Linked Model Views "Moving" (2010)
Tue, Dec 21, 2010 at 7:20:59 AM
Adding Views to Sheets in 2010
Thu, May 27, 2010 at 3:18:59 PM
Page generation time: 3.6495
