99 Users Online (98 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Component categories
Tue, Aug 30, 2005 at 11:26:31 AM | Component categories
jontramos
I have created a new family using the "generic model" template. It therefore shows up in the project browser under: familys - generic models. I want to change it so that it shows up in the casework category. Do I have to re-draw the component using the casework template? or is there a way to simply change its category so that it shows up in the project browser under casework? yes, I am new to revit (obvious?) thanks in advance for any help
Tue, Aug 30, 2005 at 11:41:22 AM | RE: Component categories
hahnmj
You don't have to redraw it. Just select the object and edit the family. Once the family editor opens go to the settings drop down menu. In that menu click on "family categories and parameters.." and there you can change what category your family is in. Then click "load into project" and override the current family parameters.
Tue, Aug 30, 2005 at 12:04:42 PM | RE: Component categories
jontramos
Thank you, I knew it would be an easy fix.
Collapsing Browser Categories & Sub Categories
Wed, Mar 4, 2009 at 9:29:51 AM
Categories
Mon, Feb 16, 2009 at 8:48:55 AM
Managing Component List
Tue, Aug 26, 2008 at 7:30:24 PM
Removing Imported Categories
Sat, May 20, 2017 at 5:26:29 AM
categories
Tue, Jun 14, 2011 at 11:20:28 PM
Page generation time: 1.1545
