17 Users Online (16 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> joined walls in elevation
Mon, Nov 30, 2009 at 5:12:51 AM | joined walls in elevation
Dafpfy
3.5 Stars: 11 Votes
Hi,
i have two walls in that are a different type but have the same exterior material, but when i look into 3d or elevation there still is a line between them,
i have joint the walls and sometimes those lines go away and sometimes they dont,
anyone know what i can do about this other then using the linework tool?
i had the same problem with a column and a exterior finish who had the same material but sometimes the join tool would delete the lines inbetween and sometimes it wouldn't,
Is there a method to revit's madnes here? :p
using rac 2010
Edited on: Mon, Nov 30, 2009 at 7:31:01 AM
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Mon, Nov 30, 2009 at 7:38:52 AM | joined walls in elevation
tim123
4 Stars: 19 Votes
The line should disappear if you join the walls.  Check that the exterior faces are exactly aligned, because even if they are slightly out the line will show (using the align tool will align them precisely).
Mon, Nov 30, 2009 at 8:35:08 AM | joined walls in elevation
Dafpfy
3.5 Stars: 11 Votes
no already checked that, thats not it,
peace is the path."
Mahatma Gandhi.
Mon, Nov 30, 2009 at 12:18:37 PM | joined walls in elevation
tim123
4 Stars: 19 Votes
If you cut and paste the two walls that don't join correctly into a fresh project and upload it we can have a look to see what the problem is.
Tue, Dec 1, 2009 at 6:32:24 AM | joined walls in elevation
Dafpfy
3.5 Stars: 11 Votes
peace is the path."
Mahatma Gandhi.
Tue, Dec 1, 2009 at 6:45:20 AM | joined walls in elevation
Dafpfy
3.5 Stars: 11 Votes
here its between the floorslab edges and the columns.
peace is the path."
Mahatma Gandhi.
Tue, Dec 1, 2009 at 7:57:18 AM | joined walls in elevation
4 Stars: 203 Votes
You have different kind of walls in that, so, use the "linework" tool to "clean" those lines....
Tue, Dec 1, 2009 at 8:25:02 AM | joined walls in elevation
Dafpfy
3.5 Stars: 11 Votes
tnx for having a look but i was looking for a solution without using the linework tool because sometimes the two different walls seem te connect and sometimes they dont,
peace is the path."
Mahatma Gandhi.
Wed, Sep 22, 2010 at 10:21:38 AM | joined walls in elevation
maribeth
Hi Dafpny,
I realize it's been almost a year since you posted your question about joined walls of different types showing up with a line between them in elevation.  Did you ever find a solution to your problem?  I'm working in Revit 2011 on a hospital project and we have many different types of walls that make up a continuous corridor wall.  You can only imagine what it looks like in elevation!  All the vertical lines that show up where the wall type changes make it look like there are a lot of jogs/plane changes in the wall.  Arggggghhhhhhh!
Any help you can offer will be appreciated!
mb
Wed, Sep 22, 2010 at 10:25:32 AM | joined walls in elevation
If the wall types are different then follow Typhoons advice in the post above.
Opening Tool in JOINED Walls
Thu, Jul 22, 2010 at 6:18:37 AM
Butt-joined glass corners walls
Fri, Mar 3, 2006 at 12:33:17 PM
joined walls don't move together
Fri, Jan 27, 2017 at 8:47:55 AM
Stacked Wall Sweep Joined but do not intersect 2013
Thu, Mar 7, 2013 at 4:45:15 PM
Just Joined Up
Fri, Apr 16, 2021 at 5:28:35 PM
Page generation time: 1.2066
