123 Users Online (122 Members):
Forums >> Revit Building >> Technical Support >> Render materials lost link
6 Posts No Rating |
I've created a house project and used the standard render materials. However, when redering I get an error which says missing materials and the render is nearly all the blue background. The materials are still in the same pathway location, and assigned to my walls etc and the Render pathway appears to be to the the same - to assetlibrary-base.fbx I can't understand why I have this problem. I would be very pleased if anyone could give guidance on a solution. Regards John
6 Posts No Rating |
Hi, More information about the problem: If I start a new project and create only one section of standard Wall the render is all blue and error message missing maps ie the brick map + bump. Also when I look at the render library the small views 'thumbnails' are all black. If I open my work in a different computer it works OK. Just wondering if my Revit software is the problem. Any suggestions would be most welcome. Regards John
Confirm that you have the correct path mapped in options, under Rendering. It should be Program Files / Autodesk Revit Architecture 2010 /Data / Rendering.
6 Posts No Rating |
Hi, Yes the render path is correct. I'm thinking of re installing my revit software to see if the package has got corrupted some how.
lost accurender material file |
Sun, Aug 31, 2008 at 12:11:56 AM
Materials not showing in render |
Wed, Jul 6, 2011 at 1:14:38 PM
Rendering was working and then it lost all the material settings. |
Mon, Nov 9, 2015 at 4:59:21 PM
Lost Materials |
Fri, Jun 8, 2007 at 6:44:54 AM
Material Editor Lost/Rendering Broken |
Tue, Oct 27, 2015 at 1:18:16 PM
Members: | 2030582 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
