32 Users Online (31 Members):
Forums >> Revit Building >> Technical Support >> attaching plinth sweep to wall under edit assembly
5 Posts No Rating |
Hi, I have attached a plinth profile to a wall type and as a result when I position doors etc they do not appear in elevation and are effectively behind the profile. I have tried to cheat the system by introduced voids, moving doors after I have positioned them in the wall but to no avail! Does anyone have any ideas? I have attached a jpeg identifing what is happening
----------------------------------- Matt Steart
7 Riverside Court
Castle Street
Barnstaple
N. Devon |
![4 Stars: 19 Votes](/images/stars_4.gif) |
The opening will only cut the sweep if the whole of the sweep is cut by the opening. Some options would be to raise the sweep to above threshold level and insert another below, or, create a separate wall for that part and join it to the main wall - the opening will cut through both walls.
Cut wall sweep in line with top of angled wall? |
Sat, Oct 15, 2016 at 11:38:08 AM
Modifying vertical structure in edit assembly |
Fri, Feb 9, 2018 at 4:27:20 PM
Brick Recess in Wall |
Thu, Feb 2, 2017 at 3:03:49 PM
11
assembly |
Mon, Apr 22, 2013 at 5:03:46 AM
Chamfered edge timber plinth |
Mon, Jun 27, 2011 at 9:52:33 AM
Members: | 2022352 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
