46 Users Online (45 Members):
Forums >> Revit Building >> Technical Support >> window above cut plane is visible. why?
I have created a new window family from scratch. In the project, some instances of this window have a sill height of 5 ft which is above the 4 ft cut plane. The problem is that even though it is above the cut plane, I can still see it. I know it is an issue with the family because if I place a stock family with a 5 ft sill height next to it, I see nothing. Is there a setting that I have not addressed? I have attached a pdf image of what it looks like in plan below a window that IS cut (3' sill ht on top, 5' sill ht on bottom). You'll see that It doesn't actually cut through, but just shows the window with no opening. I also attached the family in case that will help.
If any part of your family is cut, the family will show. That includes I N V I S I B L E L I N E S I looked at you family after I originally posted and I don't see anyinvisible lines. Did you use the standard template?
Edited on: Fri, Nov 27, 2009 at 9:42:20 AM
Window not visible, only opening - Revit 2008 |
Tue, Jan 22, 2008 at 10:30:53 PM
window does not get cut in plan view. |
Tue, Jul 12, 2011 at 10:37:20 AM
Showing High Windows Cut In Plan |
Mon, May 28, 2007 at 3:09:47 PM
trying to delete elements |
Fri, Jun 12, 2009 at 7:46:37 AM
CUT PLANE IN wINDOW |
Tue, Jan 12, 2010 at 4:43:51 PM
Members: | 2022332 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
