53 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Material on imported families
Wed, Nov 25, 2009 at 9:04:46 AM | Material on imported families
Design4p
I have imported a car as a family to Revit. When I render the 3D scene the car is white, although there is a colour shown on the file image. Any help would be appreciated.Regards John
Wed, Nov 25, 2009 at 9:09:04 AM | Material on imported families
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
Did you import it from cad or sketchup??  either way check out this video that rkitect made... http://gibsonhh.info/revit/video/sketchupRendermaterial.swf
J. Allen Ball
Mon, Nov 30, 2009 at 10:03:07 AM | Material on imported families
Design4p
Hi,  I got it from this site RevitCity, so not sure of the original file type or software that created it.  The movie suggested was very informative - thank you.  Regards John
Mon, Nov 30, 2009 at 11:48:07 AM | Material on imported families
Bhavi
You should check 2 things for this question
1) sometimes, the object which you download from Revitcity, is not complete with material application. People miss to do that when that make the object and then they realise it after using it in project.
so, Open the family of Car, pick the object(body) which doesn't show the color-> go to property-> click the small square next to the Material (under Material & Finishes)-> Pick the material-> Ok.
Save this and use it...
2) after checking this, load/reload in project. check the object's material. If it still doesn't show the color, chenge the material and try.
Basically... this whole thing is about material & properties....
Try it... I hope it works... because I faced the same problem for many downloaded objects from Revit city..
Tue, Dec 1, 2009 at 5:43:15 AM | Material on imported families
Design4p
Hi,
 Thank you the information I will try your suggestions.  Very much appreciated.
 Regards John
Massing - Applying Materials to Imported Geometry from Rhino-HELP!
Sat, Dec 10, 2011 at 6:30:10 AM
Adding Material to Families based on Cad Imports
Tue, Jun 23, 2009 at 11:37:01 AM
How do you add an imported material to Revit's material library ?
Mon, Aug 16, 2010 at 8:06:18 AM
How do I ad a material to an imported family ?
Thu, Dec 26, 2013 at 10:06:18 PM
please help- tried everything to get objects to accept material...
Thu, Apr 16, 2009 at 12:45:05 AM
Page generation time: 1.1465
