80 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Can you hide Drywall/GYP board?
Tue, Nov 24, 2009 at 9:59:08 AM | Can you hide Drywall/GYP board?
ldonkle
Our (residential) 2x4 wood walls are constructed in Revit with 1/2" of drywall, 3 1/2" wood stud, and another 1/2" of drywall.  This is causing 2 problems -
  1. Each dimension we add wants to snap to the outside of drywall, making the dimension off by a 1/2".
  2. When we use underlays, the underlay shows the outline that's either 3 1/2" thick, 4" thick, or 4 1/2" thick (depending on if the wall is no-drywall, 1-side drywall, or 2-sides drywall).  This makes it very difficult to trace walls using underlays.
We are about to just totally remove the drywall so that we can trust all our dimensions and underlays.  Is there another solution?
Tue, Nov 24, 2009 at 10:34:52 AM | Can you hide Drywall/GYP board?
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
I'm kinda lost.... what are you trying to accomplish? A picture of what you trying to do might help. As far as snapping dimension...you can always use the "tab" to select the sides of the wall you want to dimension... (i.e., center, outside, inside....)
 "If you tell the truth, you don't have to remember anything"
Tue, Nov 24, 2009 at 10:37:35 AM | Can you hide Drywall/GYP board?
ldonkle
Tue, Nov 24, 2009 at 10:50:46 AM | Can you hide Drywall/GYP board?
3.5 Stars: 395 Votes
Set your dimensions to face of core and pay attention to what you are dimension to...
THIS IS VERY IMPORTANT IN REVIT
Multiple items may exist in the same place  (Tab to select correct one).  If you do not pay attention to what you are dimensioning to, you will get some nasty surprises.
Tue, Nov 24, 2009 at 10:59:35 AM | Can you hide Drywall/GYP board?
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
Also when dimensions to different parts of the wall if you will hold your cursor over the line you want to dimension to and hit tab then it will tab threw the different lines.
J. Allen Ball
Revit Architecture 2010 Certified Professional
Tue, Nov 24, 2009 at 11:20:17 AM | Can you hide Drywall/GYP board?
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
TAB will always be your bestfriend in Revit. Smile
Bill of Materials - drywall
Wed, Jan 9, 2008 at 2:46:38 PM
WALL CONN. need help asap
Sat, Dec 6, 2008 at 3:09:12 PM
Stud Wall-Make finishes disappear
Thu, Jan 29, 2009 at 10:36:40 AM
NEW Gyp on EXISTING Stud wall
Tue, Mar 6, 2007 at 11:24:19 AM
Material Cost Analysis in Schedules
Wed, Jan 13, 2010 at 6:55:37 PM
Page generation time: 0.3527
