49 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> eliminating extranious data from linked files
Fri, Nov 20, 2009 at 8:44:28 AM | eliminating extranious data from linked files
KKERRIDGE
KKERRIDGE Avatar
2.5 Stars: 3 Votes
Today, while looking for anything in our linked files from the architect I noticed something. We are leaving in all the sheets, and views from the architectural file then linking it into our revit file. We then create our own views and sheets in our model.
I was debating saving the architectural file as is (for refrence), then cleaning out the sheets& views before linking it in for MEP work.
*Have other companies taken this approach, and has it helped them with thier processing speed?*
When I tried this on a test file (save as & detached from central) I was able to reduce the size of the link file by 58-53% (i tried it on two separate projects) but I have been told in the past that revit file size is not necessarily the ONLY key to faster file processing speeds.
autocad linked files and refresh
Tue, Apr 7, 2009 at 2:12:36 PM
View Properties of Linked Revit Files
Mon, Feb 15, 2010 at 9:56:22 PM
Linked Files Revit 2009
Wed, Aug 31, 2011 at 3:27:11 PM
linked files - material override?
Mon, Aug 31, 2009 at 9:59:52 AM
Managing linked autocad files
Thu, Dec 3, 2009 at 9:19:42 AM
Page generation time: 1.0978
